hopbin9 Posted November 23, 2010 Share Posted November 23, 2010 Hi, Is it possible to create highlights on the specular bright spots on objects (like small lens flares). Thanks, Quote Link to comment Share on other sites More sharing options...
malexander Posted November 23, 2010 Share Posted November 23, 2010 Yep, you can do this with a Limit, a Defocus & an Add COP. 1. Add a Limit COP 1a. Set the lower limit to the lowest hotspot value you want to flare 1b. Disable the upper limit 1c. Change "Clamped Values" to "Replace with Black" 2. Add a defocus COP to the Limit 2a. Play with the defocus size 2b. Play with the Boost factor, threshold and level. Threshold should likely be the hotspot value you entered for the Limit. 3. Add an Add COP 3a. Wire in Defocus 3b. Wire in the input to the Limit COP (the original node). Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 23, 2010 Author Share Posted November 23, 2010 wow, that looks really cool. Thanks Exactly what I was looking for. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 23, 2010 Author Share Posted November 23, 2010 Is there a way to scale the defocus based upon depth? My image source as a Pz channel, but I new to working with channels in DOP. Quote Link to comment Share on other sites More sharing options...
malexander Posted November 23, 2010 Share Posted November 23, 2010 You'll need to use the Pz image as a mask to the Defocus COP, and turn on "Per Pixel Defocus". But before you add Pz as a mask, you'll need to preprocess it a bit to get in the 0-1 mask range that Defocus expects. Append an Equalize COP to the Pz image, which will maps its near-far range to 0-1. Then a gamma COP will alter the rate at which the defocus effect is applied with respect to depth. Also make sure that the Defocus COP's Mask plane is set to the Pz plane, if that's the name of the depth channel. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted November 23, 2010 Author Share Posted November 23, 2010 Thanks, your help has been very valuable. Need anything, let me know. Quote Link to comment Share on other sites More sharing options...
malexander Posted November 24, 2010 Share Posted November 24, 2010 Glad to help. Just sing the praises of Houdini, that's all I need Quote Link to comment Share on other sites More sharing options...
