mountain sop to only displace in Y direction?
locvio
mountain SOP will displace terrain in both up and down directions:
Would like to only displace ONLY UP.. So needs something like
absolute value of Y displacment...
Im just transforming the result up in Y a bit to get kinda close,
but getting some problems at edges that are not ideal.
thanks!
Edited by locvio
thanks!
The mountain applies noise in the direction of a point normal, if it exists, or defaults to the primitive normal. Noise itself, depending on the type of noise, generally falls in the range of -1 and 1 which means that you will have it moving in positive and negative directions.
You could switch to Alligator Noise which has a range of 0-1 to have it only in the positive. If you want a perlin noise but only applied in the positive Y, you could use a point sop and in the Position Y parameter, put
$TY + abs(noise($TX, $TY, $TZ))
