titor Posted December 17, 2010 Share Posted December 17, 2010 Hello, I'm here because I havec a strange issue. Since I tried to deal with OTL, and install one i did, Houdini doens't start and I got this error message Error: Beauty composite shader failed to compile. No color corrections will be applied to the beauty pass then in houdini console : 1152 : Fatal Error : Segmentation Fault Saving application data to C:/Users/xxx/appData/Local/Temp/xxx.1152.hip what can i do ? Thanks for your answers Quote Link to comment Share on other sites More sharing options...
titor Posted December 17, 2010 Author Share Posted December 17, 2010 Seems to be fixed i restarted but still kinda freaky Quote Link to comment Share on other sites More sharing options...
malexander Posted December 17, 2010 Share Posted December 17, 2010 Did you change the HOUDINI_PATH at all during your attempts to install the OTL? That might explain why it can't suddenly can't compile the beauty composite shader, if it isn't found. Houdini should still work without it, so perhaps it's triggering another issue further on. Quote Link to comment Share on other sites More sharing options...
