Particle controlled FLIP fluids
Hi, i'm trying to make explosion of barrel with water. I want to control my flip particles with pop network, inside dop network. Actually, i need flip particles to inherit initial velocity of particles from my popnet. Well, when i create flip object from shelf, i get pop solver attached to flip solver and it contains particles generated by flipfluidobject. So, yes, i can do some staff in this pop solver, but how can get my geometry information inside this popnet(pop solver), because i want to use, lets say my N attribute to set initial speed. Here is scene file, please help me with this setup.Thanks.
barrel.hip
You can perform a pointcloud lookup with a voppop.
pcopen a op:/obj/mysop/my_custom_normals[$FF]
and pcfilter out the N.
Add that to the acceleration.
On the pops level:
Set the Activation of that vop pop to: $FF<=2 -> I am not sure it actually solves the popsolver on frame 1, so I made it active for frame 1 and 2.
Just a few notes:
*) when dealing with pointclouds and modifying them you will need to recook your sim for the pointcloud to refresh.
Or have a look at your file.
You can get good results layering noise in your normals and also having different amplitutes mixing in those normals.
barrel_02.hip
  • Like 4
