Omy Posted December 20, 2010 Share Posted December 20, 2010 i have simulated a particle to flow on the curve.I have simulated this using fiedforce and used pop solver inside dops.please let me know how to instance an object to it. Many Thanks Quote Link to comment Share on other sites More sharing options...
Macha Posted December 20, 2010 Share Posted December 20, 2010 (edited) Here is one way for you. The easiest would be a copy-sop though. If you want to get across attributes with the posted method its gets a little trickier (but possible with instancepoint() ) Oh, and in case the problem lies with getting the points out of dops, use the dop import sop with "import style" set to "fetch geometry". instance.hipnc Edited December 20, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
Omy Posted December 20, 2010 Author Share Posted December 20, 2010 Here is one way for you. The easiest would be a copy-sop though. If you want to get across attributes with the posted method its gets a little trickier (but possible with instancepoint() ) Oh, and in case the problem lies with getting the points out of dops, use the dop import sop with "import style" set to "fetch geometry". Hi the thing is that i have animated the object.I tried with copy sop but still seems to be a problem as the animation does not run correctly across the curve Quote Link to comment Share on other sites More sharing options...
