Omy Posted December 24, 2010 Share Posted December 24, 2010 Could any body help me in taking render passes in houdini 11.I used to do with houdini 10 but here i have no green color parameters inside the shops? Quote Link to comment Share on other sites More sharing options...
Macha Posted December 25, 2010 Share Posted December 25, 2010 (edited) Find out what parameter you want to output. I admit this can be tricky in big networks, then connect it to a parameter node (set to Export "When Input is connected"). Name the parameter and make sure it is of the right type and context (usually default is ok).Then in the render node add image plane and set name and type to the same value as you did with the exported parameter. Edited December 25, 2010 by Macha Quote Link to comment Share on other sites More sharing options...
