Making instances respecting the point geometry normals?
Do you have any other attributes overriding your N?
Specifically orient or up could change the alignment of the instances.
This is the order of preference:
orient -> up -> N -> V
Did you create the normals with a sop or inside a vopsop? Make sure your N is a vector not a float[3]. You can check this in a spreadsheet and see if your data is N[1],N[2],N[3] (this is the float[3] representation) or Nx, Ny, Nz (this is the vector representation).
Also make sure your normals are not zero.
Peter is absolutely spot on of course.
One thing to add though. Not sure I'm completely right (please correct me if it's wrong) but I think the orient attribute is a quaternion, so the first 3 components are the axis and the last should be the angle. That could be confusing otherwise.
"orient" is a quaternion - and yes, the axis is first, then the angle.
I think the only difference with "rot" is the order of operations. I think orient happens first, then scale and translate and then rotate:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=6679&highlight=copy+sop
in regards to the scale:
you should be able to use both the pscale (float) attribute as well as the scale (float[3]) attribute
-> haven't tested this, but should work - otherwise there are other ways around it with delayed loads and instancepoint() expression:
http://www.peterclaes.be/blog/?p=34 (hip files at the bottom)
(in the same way you use the attributes with the copy sop .. that's why it is a good idea to prototype point-based instancing with the copy sop - and far fewer template points).
