translucent ray-trace shadows on opaque objs
hi,
I was wondering if it is possible to make direct light ray-trace self shadows decay after each pass through surface while surface is completely opaque.
I have done it with depth maps by setting my obj's opacity to .5 pre-rendering shadow map and using that map on the same object with opacity value 1.
Could anybody suggest how it could be done with ray-traced shadows? Examples would be totally awesome :)
Thanks!
not quite sure what the purpose of this is, but here's how you would achieve this gag using raytrace shadows
its pretty chill
its pretty chill
total awesomeness :)
thanks Brian.
well for example I am using it to fake SSS on tree leaves. I took care of the color and now shadow is also decaying with each pass through a leaf...
but taking this further in therms of efficiency I was thinking how to limit this effect to a certain penetration level since opacity approach slows down ray-tracer a lot. Lets say switching opacity to 1 after 5th pass.
or getting the same effect without modifying opacity I am not sure if its possible but maybe by multiplying shadow intensity with each pass...? or I am just talking about the same thing since shadow ray still have to travel further after hitting opaque surface?
Edited by PhasmaCeritus
