ehsan parizi Posted December 31, 2010 Share Posted December 31, 2010 (edited) Hi; I've downloaded the PLE version(or whatever they call it right now) of Houdini 11 on my laptop and there are 2 problems! 1. I can not open the help! 2. this one is really annoying, when I want to see my geometry in viewport, and I select the smooth shaded, it shows nothing! it does render but doesn't show anything in the viewport, I did not have this problem with the previous version of Houdini on this machine! so it looks like a bug to me!(if I open an existing file, it works just fine, but when I make a new file, the problem is still there!) Edited December 31, 2010 by ehsan parizi 1 Quote Link to comment Share on other sites More sharing options...
Macha Posted December 31, 2010 Share Posted December 31, 2010 I had a very similar problem last week. I don't know if it helps but what I did is: -create a new Scene View tab -move camera a bit and return to your old scene view -now both views work correctly It might not work in your case but it's worth a try. Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted December 31, 2010 Author Share Posted December 31, 2010 it's a very strange kind of problem, sometimes it works, sometimes it doesn't! But right now, I just used an old file, and cleaned it, and saved it as an empty template, and it works fine! but I don't know what's causing the problem anyway. btw thanks for the answer Quote Link to comment Share on other sites More sharing options...
3__ Posted December 31, 2010 Share Posted December 31, 2010 Try sending the problematic file off to support at Sidefx, along with your houdini & OS versions, hardware specs & any steps to reproduce the problem. Quote Link to comment Share on other sites More sharing options...
