Hash?
Macha
Does anybody know of a way to get/implement a fast hash function for points?
I have various streams of pops merging and want the particles to have unique id. $PT doesn't work because the particles are born and die away irregularly and I want the ids to be persistent.
I could randomize some values and hope for the best I suppose but I wonder if there is a proper way to do this.
Edited by Macha
i suppose you are doing this after simulation with cached particles in SOPs
each particle sim has detail attribute "nextid" which contain "id" which will be used on next born particle
so if you are merging multiple sims together, just add sum of "nextid" attributes from all already merged sims to "id" of all particles in current sim
and that way offseting those ids to unique values
or you can add nextid-1 to be more exact, but it doesn't really matter
Thanks for the reply but I miss something there. I still get multiple identical ids. The particles may also die away over the course of the animation so I am not sure how it would ensure uniqueness. The $NEXTID also changes from frame to frame, so how can we use it in an expression and retain a unique, persistant id?
(by the way, having a hash function would be useful in other scenarios as well (changing $NPT and chops!))
id.hip
Edited by Macha
as i said, i assume that all sequences are cached, so you can take nextid from the last frame
otherwise it would be difficult
and you need to add nextid before merge
so for first stream nothing
for 2nd stream id+nextid1(from last frame)
for 3rd stream id+nextid1+nextid2
or you can add high mumber to second stream ids, 2x high number to third and so on
that number should be higher than potential particle count of each stream
or maybe easier and doesn't need caching
convert ID to float
then add 0.1 for second stream, 0.2 for third, ..., 0.9 for 10th
or if you need more use lower steps
then merge all together
your ids will be unique
you can multiply them by 10 now and convert back to integer
or never convert to float, but then the math would be
*10 for first stream
*10+1 for second
*10+9 for 10th
Thanks Thomas. I tried the "add a high number" before but I have huge amounts of particles and they often overlap and I need to go hunting pointcounts, and I need to create extra attributes and update them throughout my network. It works but it's all messy after a while.
I'll keep thinking about your nextid idea. Obviously you have thought about it before and know more about it than me!
I have never needed that before, it's just a few ideas
I am starting to like the approach I posted in the example, because it doesn't require caching and even after merging you can tell which particle is from which stream and they have unique ids
but it depends on what you need it for
What I done before, if you are interested, is to sum the id and a number unique to the popnet, and then generate a random number out of that, multiply it by something large and create an integer attribute out of it. It kind of works but with huge pointcounts you get a few id overlaps.
