weeman Posted January 9, 2011 Share Posted January 9, 2011 I am fairly new to houdini, i have bgeo sequence of an object moving around a scene, I have then fractured the object using voroni fracture and turned it into an RDB glue object. when i play back the animation gravity starts effecting the object as it it not in contact with the ground plane, I can turn the gravity off but when the fractured object gets hit i need gravity to act on the pieces that break off only to allow them to fall to the ground. Im sure there is a way to sole this using groups, but due to lack of experience am not sure howe to approach this Quote Link to comment Share on other sites More sharing options...
