photoreel Posted January 11, 2011 Share Posted January 11, 2011 Hello everyone, I'm not able to get the vopsop_foamparts.hip example file to open correctly on my machine. I'm running Houdini 11.0.581 on Mac OS 10.6.4.5. HOT is working fine on my machine, but when I try to open the vopsop_foamparts.hip example I get a bunch of errors and I can't run a simulation. Here are the errors I'm getting when trying to open the file: Warning: Skipping unrecognized parametere "atten_0". Skipping unrecognized parametere "atten_1". Skipping unrecognized parametere "atten_2". Skipping unrecognized parametere "folder2". Skipping unrecognized parametere "areashape". Skipping unrecognized parametere "areasamples". Not enough elements found for parameter "/obj/distantlight 1 Area Size." Skipping unrecognized parametere "areausemap". Skipping unrecognized parametere "folder5_1". Skipping unrecognized parametere "alowmotionblur". Has anybody got the vopsop_foamparts.hip to work with Houdini 11? If so, could you post it? Or if you have a different file with working foam and/or spray that would be a big help. Thanks, Michael Quote Link to comment Share on other sites More sharing options...
Macha Posted January 11, 2011 Share Posted January 11, 2011 Have you tried installing the right version of compiled HOT for your version of Houdini? I have noticed that they must coincide precisely for it all to work. Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 12, 2011 Author Share Posted January 12, 2011 Have you tried installing the right version of compiled HOT for your version of Houdini? I have noticed that they must coincide precisely for it all to work. Hey Macha, Thanks for your quick response. Yeah, I compiled HOT myself from source code for my build of Houdini, so it should be okay. I'm wondering if perhaps the example file was creating using a different build of Houdini and that could be what's causing the issue. Michael Quote Link to comment Share on other sites More sharing options...
eloop Posted January 12, 2011 Share Posted January 12, 2011 Are you sure that you've correctly installed the VEX extension ? Double check the installation documentation, particularly the bit about VEXdso files. That error is not the cause of the problem, it's just related to changes in houdini ops. -Drew Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 12, 2011 Author Share Posted January 12, 2011 Are you sure that you've correctly installed the VEX extension ? Double check the installation documentation, particularly the bit about VEXdso files. That error is not the cause of the problem, it's just related to changes in houdini ops. -Drew Hey Drew, Thanks for your post. After I compiled HOT from the source code for H11.0.581, I had to manually copy the files from the binary distribution I created into the appropriate folders on my machine (more on why I had to do this below.) However, I didn't copy over the "VEXdso" file from the binary distribution I had created, because a VEXdso file already resided on my machine and it had a lot more information in it than the one that was generated by compiling the source code. Even though I didn't copy over the VEXdso file, HOT appeared to be working, but it seems that this has created an issue now. When I compiled HOT I was running Mac 10.6.4 (I'm now on 10.6.5) and the instructions posted here http://anusf.anu.edu...ini/ocean/docs/ about how to install the binary distribution weren't working with Mac 10.6.4 and Houdini 11.0.581. I also tried the instructions on Houdini's site (see link below) about modifying the DSO path, but that didn't work for me either. Can you tell me how I should modify the VEXdso file that already exists on my computer to include the information in the VEXdso that is created by HOT? I've attached the VEXdso file from my computer (not the one created by HOT) to this email. I've pasted the contents of my VEXdso file below. Thanks for your help! Great job on HOT! Michael #ifndef __HFS_VEXdso__ #define __HFS_VEXdso__ // // VEXdso // // This file contains the definitions for VEX plug-in functions. // // There are currently no dynamic loaded VEX instructions. // // Please see $HH/vex/dso/VEX_VexOp.html for more details. // // // Since Windows dynamic objects have a different file extension than // most unix platforms, we define a macro which makes the correct // filename. We also simplify the path construction a little. // #if $HOUDINI_OS == "Windows" #define DSO_FILE(filename) vex/filename.dll #else #define DSO_FILE(filename) vex/filename.so #endif // Define VEX plug-ins here // demobox DSO_FILE(VEX_Ops.so) // Make sure to undefine the macro before doing any further includes #undef DSO_FILE // // When copying this file to other locations in the HOUDINI_PATH, // please uncomment the following line (or change it) so that any // other VEXdso files get processed. // // #include "$HFS/houdini/vex/VEXdso" #endif Quote Link to comment Share on other sites More sharing options...
eloop Posted January 12, 2011 Share Posted January 12, 2011 I wouldn't advocate using your solution of copying the files into the houdini distribution. What went wrong when you followed the docs ? -D Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 12, 2011 Author Share Posted January 12, 2011 Hey Drew, I should probably mention first that I'm on mac os 10.6.5 right now and I was on 10.6.4 when I compiled HOT. To make a long story short, at first I couldn't get SOP_Star.C to compile, but I eventually figured out that I had to chmod - R 777 my Houdini.framework folder to get read/write access to that folder and its sub-folders. Once I did that I was able to compile SOP_Star.C. So, from there I compiled HOT from the source code for Houdini 11.0.581. After compiling HOT, I was not able to get HOT running. I also created a folder and put the binary distribution of HOT I had compiled into it and using "export HOUDINI_DSO_PATH=" from the Houdini terminal, told Houdini to look in the folder I had created for the binary distribution of HOT. I think that this didn't work at the time (it was a few weeks ago.) As a test just now, I exported the dso path again to that folder and ran an "hconfig -ap" from the Houdini terminal. The results are posted below. After that, I tried opening houdini again and opening the vopsop_foamparts.hip. Unfortunately, it still didn't open even though it looks as though the dso path is correct. HOUDINI_DSO_PATH := "/Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9" The search path for loading custom plug-ins (Dynamic Shared Objects or Dynamic Link Libraries). Default path: '@/dso_^;@/dso' Where @ is replaced with HOUDINI_PATH and ^ is replaced with macos Directories searched (in order) are: 1) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9" Also, just now I went into the Houdini terminal and did an "export HOUDINI_PATH=" to where I put the binary distribution of HOT. Then I ran an "hconfig -ap" the results of which are: HOUDINI_PATH := "/Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9" Directories searched (in order) are: 1) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9" I then reopened Houdini and tried to open the example file again, but I got the same errors as before. Using the approach of exporting the houdini path wasn't working for me when I was originally tried to install HOT (I was unable to create an ocean sop after diving into a grid.) This is what eventually led me to manually copy over the files from the binary distribution. It seemed (and still does) that exporting paths wasn't working for me. Copying the files manually was a suggestion from another user, so I think a few people may be having this issue (at least on mac os 10.6.4 and 10.6.5) I don't have any programming experience and I rarely use the terminal window, so user error is definitely a possibility here. Thanks for your help! Best regards, Michael Quote Link to comment Share on other sites More sharing options...
eloop Posted January 12, 2011 Share Posted January 12, 2011 Don't forget the ":&" that is supposed to be at the end of HOUDINI_PATH. It is essential. -Drew Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 12, 2011 Author Share Posted January 12, 2011 Don't forget the ":&" that is supposed to be at the end of HOUDINI_PATH. It is essential. -Drew Hey Drew, Thanks for your reply. On your website it is written as ";&" instead of ":&" The reason that I did not included the ";&" is because on Mac OS X, I would get the following error when using it from the houdini terminal Workstation4:Resources michaelmcneff$ export HOUDINI_PATH=/Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9;& -bash: syntax error near unexpected token `&' As you recommended, I just tried using ":&" at the end of the HOUDINI_PATH and then tried opening up Houdini and opening the vopsop_foamparts.hip file, but unfortunately I got the same errors as before. Here's the results of running an "hconfig -ap" after putting the ":&" at the end of the HOUDINI_PATH. Workstation4:Resources michaelmcneff$ export HOUDINI_PATH=/Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9:& [1] 2863 Workstation4:Resources michaelmcneff$ hconfig - ap Usage: hconfig [options] This program will print out all the environment variables that Houdini checks for configuration. With no arguments, the current environment will be printed out. Options: -h Prints this usage information. -o Prevent check for old environment variables. -a List all variables whether they are set or not. -H [var_name] [var_name...] List help for specified variables If no variables are named, a complete list will be printed. -p List the non-default search path variables. To print out all paths, use the -a option with the -p option. -b List build machine information Examples: example % hconfig -ap Show all path variables and their expansions example % hconfig -a Show all variables and their values example % hconfig Show variables overriding the default behaviour example % hconfig -p Show path variables overridden example % hconfig -H SHELL Show help for the SHELL variable example % hconfig -H Show help for all variables [1]+ Done export HOUDINI_PATH=/Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9: Workstation4:Resources michaelmcneff$ Thanks for all your help. Michael Quote Link to comment Share on other sites More sharing options...
eloop Posted January 12, 2011 Share Posted January 12, 2011 Follow the documentation, ie semicolon and don't forget to enclose the value in ""'s. BTW I develop on OSX so I know this works :-) -Drew Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 12, 2011 Author Share Posted January 12, 2011 Hey Drew, Glad to hear that you develop on OSX! That's a relief! I just reinstalled Houdini 11.0.581 and followed the documentation to install the binary distribution of HOT (that I compiled.) Unfortunately, it appears that this didn't work. When I dive into a grid, I am no longer able to apply an ocean sop. Below is what I did to install the binary distribution and the results of an hconfig -ap that I ran after it. Thanks again for your help. The Houdini 11.0.581 environment has been initialized. Workstation4:Resources michaelmcneff$ export HOUDINI_PATH="/Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9;&" Workstation4:Resources michaelmcneff$ hconfig -ap Special characters in path definition are: @ - Typically expands to the HOUDINI_PATH. Thus, if the HOUDINI_PATH was set to: $HIP $HFS/houdini $HOME/houdini a path defined as "@/vex" would expand to the paths $HIP/vex $HFS/houdini/vex $HOME/houdini/vex = - This expands to the $HIP variable. This path will always point to where the currently loaded hip resides. & - The ampersand character expands to the "default" path. For example, to add a directory to the a path without worrying about what the default path should actually be, simply set the path to: "/mypath;&". This will search the "/mypath" path first, then search the default path. ^ - Some paths are used for multiple directories. For example, the HOUDINI_VEX_PATH is used to define the search path for Surface, Displacement, Sop, etc. VEX shaders. For VEX, the ^ symbol expands to the shader type. Thus, if the HOUDINI_VEX_PATH variable is set to something like "/usr/local/vex;$HOME/vex/^", when loading Surface shaders, the following directories will be scanned: /usr/local/vex $HOME/vex/Surface and if Sop shaders are being searched for, the following paths will be searched: /usr/local/vex $HOME/vex/Sop Common paths are set to: $JOB = <not defined> $HIP = /Library/Frameworks/Houdini.framework/Versions/11.0.581/Resources $HOME = /Users/michaelmcneff $HSITE = <not defined> $HFS = /Library/Frameworks/Houdini.framework/Versions/11.0.581/Resources HOUDINI_PATH := "/Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9;&" The path of directories where Houdini looks for configuration files. Directories searched (in order) are: 1) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9" 2) "$HOME/Library/Preferences/houdini/11.0" 3) "/Users/Shared/houdini/11.0" 4) "$HIP/houdini" HOUDINI_AUDIO_DSO_PATH := "@/audio" The search path for loading custom audio format plugins for reading and writing audio or channel files (.so, .dll). Default path: '@/audio' Where @ is replaced with HOUDINI_DSO_PATH Directories searched (in order) are: 1) "$HIP/houdini/dso/audio" HOUDINI_CLIP_PATH := ".;@/clips;@/clip" The path of directories where Houdini looks for .clip and .bclip channel files Default path: '.;@/clips;@/clip' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "." HOUDINI_CUSTOM_PATH := "@/^" The path of directories where Houdini looks for custom panel information. Default path: '@/^' Where @ is replaced with HOUDINI_PATH and ^ is replaced with custom Directories searched (in order) are: HOUDINI_DESK_PATH := "@/^" The path of directories where Houdini looks for desktops Default path: '@/^' Where @ is replaced with HOUDINI_PATH and ^ is replaced with desktop Directories searched (in order) are: 1) "$HIP/houdini/desktop" HOUDINI_DSO_PATH := "@/dso_^;@/dso" The search path for loading custom plug-ins (Dynamic Shared Objects or Dynamic Link Libraries). Default path: '@/dso_^;@/dso' Where @ is replaced with HOUDINI_PATH and ^ is replaced with macos Directories searched (in order) are: 1) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/dso" 2) "$HOME/Library/Preferences/houdini/11.0/dso" 3) "$HIP/houdini/dso" HOUDINI_GALLERY_PATH := "@/gallery" Specifies the search path to the directory that contains the gallery files. If this variable is not set, Houdini looks in the 'gallery' subdirectories of the standard search path, which includes $HFS/houdini/gallery/, for example. Gallery files specify the predefined parameter values for any node type, much like the presetsd. However, they are used predominantly for defining shaders and materials. Default path: '@/gallery' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "$HIP/houdini/gallery" HOUDINI_GEOMETRY_PATH := ".;@/geo" The search path for geometry files. Default path: '.;@/geo' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "." 2) "$HIP/houdini/geo" HOUDINI_GLSL_PATH := ".;@/ogl2" The search path for GLSL code. Setting this path will override the default path of $HOUDINI_PATH/ogl2/. Searching for the dialog scripts is independent of GLSL searching and is controlled by the HOUDINI_PATH. Default path: '.;@/ogl2' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "." 2) "$HIP/houdini/ogl2" HOUDINI_IMAGE_DSO_PATH := "@/fb" The search path for loading custom image format plugins for reading and writing images of that format (.so, .dll). Default path: '@/fb' Where @ is replaced with HOUDINI_DSO_PATH Directories searched (in order) are: 1) "$HIP/houdini/dso/fb" HOUDINI_MACRO_PATH := "@/^" The search path for toolbar macro files. Default path: '@/^' Where @ is replaced with HOUDINI_PATH and ^ is replaced with scripts/opmacros Directories searched (in order) are: 1) "$HIP/houdini/scripts/opmacros" HOUDINI_OPLIBRARIES_PATH := "@" The path of directories where Houdini looks for OPlibraries files for loading OTL files at startup. OPlibraries files are only used if the Operator Type Manager is configured to use them. Otherwise OTL files are scanned for directly. This path by default is equal to the HOUDINI_OTL_PATH. Default path: '@' Where @ is replaced with HOUDINI_OTL_PATH Directories searched (in order) are: 1) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9" 2) "$HOME/Library/Preferences/houdini/11.0" 3) "/Users/Shared/houdini/11.0" 4) "$HIP/houdini" HOUDINI_OTLSCAN_PATH := "@/otls" This path specifies the directories Houdini will search for OTL files. This value is only used if the Operator Type Manager is configured not to use OPlibraries files to find OTL files. The default for this value is the HOUDINI_OTL_PATH with "/otls" appended to each directory in that path. Default path: '@/otls' Where @ is replaced with HOUDINI_OTL_PATH Directories searched (in order) are: 1) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/otls" 2) "$HIP/houdini/otls" HOUDINI_OTL_PATH := "@" This path is not used directly by Houdini. It is used to provide default values for the HOUDINI_OPLIBRARIES_PATH and HOUDINI_OTLSCAN_PATH values in a way that is backward compatible (since HOUDINI_OTL_PATH used to mean what HOUDINI_OPLIBRARIES_PATH now means). Default path: '@' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9" 2) "$HOME/Library/Preferences/houdini/11.0" 3) "/Users/Shared/houdini/11.0" 4) "$HIP/houdini" HOUDINI_OUTLINEFONT_PATH := "@/fonts" This is the path searched for Adobe Type 1 or True Type fonts used in the font SOP, font COP Default path: '@/fonts' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "$HIP/houdini/fonts" HOUDINI_SCRIPT_PATH := "@/scripts" The path of directories where Houdini searches for scripts. This includes .cmd files for hscript, .class files for the java command, .tcl and .tk files for the tcl and tk commands, and command scripts for the Alfred Output Driver. Default path: '@/scripts' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "$HIP/houdini/scripts" HOUDINI_SOHO_PATH := "@/soho" The path of directories used by soho. Default path: '@/soho' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "$HIP/houdini/soho" HOUDINI_TEXTURE_PATH := ".;@/pic;@/map;@/maps" The search path for loading images. This includes .rat files and other 2D formats as well as .i3d 3D texture files. Default path: '.;@/pic;@/map;@/maps' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "." 2) "$HIP/houdini/pic" HOUDINI_TOOLBAR_PATH := "@/^" The search path for factory and custom shelves and shelf tools (i.e., shelf files). The shelf files are searched for and loaded when Houdini starts. They can define new tools that appear in the TAB menu or new groupings of tools (ie, toolbars or shelves) which can be displayed in the shelving area (usually, just below the main menu). Default path: '@/^' Where @ is replaced with HOUDINI_PATH and ^ is replaced with toolbar Directories searched (in order) are: 1) "$HIP/houdini/toolbar" HOUDINI_UI_APP_PATH := "@/^" An application search path for .ui definition files. Use care when changing this path, otherwise the graphical Houdini applications may not start. Default path: '@/^' Where @ is replaced with HOUDINI_UI_PATH and ^ is replaced with Applications Directories searched (in order) are: 1) "$HIP/houdini/config/Applications" HOUDINI_UI_AUDIO_PATH := "@/^" An application search path for the audio notification files used by the interface. Use care in changing this path, otherwise audio notifcations may stop working. Default path: '@/^' Where @ is replaced with HOUDINI_UI_PATH and ^ is replaced with Audio Directories searched (in order) are: 1) "$HIP/houdini/config/Audio" HOUDINI_UI_CURSOR_PATH := "@/^" An application search path for locating the Houdini mouse cursor set. Use care when changing this path, otherwise the mouse cursor may not reflect its current context. Default path: '@/^' Where @ is replaced with HOUDINI_UI_PATH and ^ is replaced with Cursors Directories searched (in order) are: 1) "$HIP/houdini/config/Cursors" HOUDINI_UI_ICON_PATH := "@/^" The search path for icon files. Setting this path will override the default of $HOUDINI_PATH/config/Icons. Default path: '@/^' Where @ is replaced with HOUDINI_UI_PATH and ^ is replaced with Icons Directories searched (in order) are: 1) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/config/Icons" 2) "$HOME/Library/Preferences/houdini/11.0/config/Icons" 3) "$HIP/houdini/config/Icons" HOUDINI_UI_PATH := ".;@/config" The base path for all user interface files. Use extreme care when changing this variable, or graphical Houdini applications may not start. Before adding paths to this variable, check the other HOUDINI_UI variables to see if one or more of those paths will accomplish what you need. Adding a new path to this variable can be expensive. Default path: '.;@/config' Where @ is replaced with HOUDINI_PATH Directories searched (in order) are: 1) "." 2) "$HOME/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/config" 3) "$HOME/Library/Preferences/houdini/11.0/config" 4) "$HIP/houdini/config" HOUDINI_VEX_PATH := ".;@/vex/^" The search path for VEX code. Setting this path will override the default path of $HOUDINI_PATH/vex/. Searching for the dialog scripts is independent of VEX searching and is controlled by the HOUDINI_PATH. Default path: '.;@/vex/^' Where @ is replaced with HOUDINI_PATH and ^ is replaced with Displacement, Fog, Light, Shadow, Surface, Photon, BSDF, Chop, Cop2, Image3d, Sop, Pop, CVex Directories searched (in order) are: 1) "." 2) "$HIP/houdini/vex/Displacement" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Fog" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Light" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Shadow" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Surface" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Photon" OR -------------------------------- 1) "." OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Chop" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Cop2" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Image3d" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Sop" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/Pop" OR -------------------------------- 1) "." 2) "$HIP/houdini/vex/CVex" Workstation4:Resources michaelmcneff$ Quote Link to comment Share on other sites More sharing options...
eloop Posted January 12, 2011 Share Posted January 12, 2011 Hmm, I'm now wondering if you are using tcsh or bash as your command shell ? Can you post the output of "hconfig" with no extra flags. -Drew Quote Link to comment Share on other sites More sharing options...
eloop Posted January 12, 2011 Share Posted January 12, 2011 Sorry, I can see from your "hconfig -ap" that the HOUDINI_PATH variable is correct. Can you post the output of HOT build process, ie > hython setup.py build Also can you post the output of > ls -lR /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9 -Drew Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 12, 2011 Author Share Posted January 12, 2011 Workstation4:Resources michaelmcneff$ hconfig HFS := '/Library/Frameworks/Houdini.framework/Versions/11.0.581/Resources' HOME := '/Users/michaelmcneff' HOUDINI_DESKTOP_DIR := '/Users/michaelmcneff/Desktop' HOUDINI_TEMP_DIR := '/tmp' SHELL := '/bin/bash' USER := 'michaelmcneff' Thanks, Michael Quote Link to comment Share on other sites More sharing options...
eloop Posted January 12, 2011 Share Posted January 12, 2011 Hang on, where is the HOUDINI_PATH you've set ? -Drew Workstation4:Resources michaelmcneff$ hconfig HFS := '/Library/Frameworks/Houdini.framework/Versions/11.0.581/Resources' HOME := '/Users/michaelmcneff' HOUDINI_DESKTOP_DIR := '/Users/michaelmcneff/Desktop' HOUDINI_TEMP_DIR := '/tmp' SHELL := '/bin/bash' USER := 'michaelmcneff' Thanks, Michael Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 13, 2011 Author Share Posted January 13, 2011 Hang on, where is the HOUDINI_PATH you've set ? -Drew Hey Drew, I think that it is there now. I just recompiled HOT from the source code and put the new binary distribution in the same location I've been using. I then exported the HOUDIN_PATH again to that location, just be sure. I just opened Houdini and tried to use HOT again, but unfortunately I still didn't have any luck. Here's the results of "hconfig" I think shows the path now. Workstation4:src michaelmcneff$ hconfig HFS := '/Library/Frameworks/Houdini.framework/Versions/11.0.581/Resources' HOME := '/Users/michaelmcneff' HOUDINI_DESKTOP_DIR := '/Users/michaelmcneff/Desktop' HOUDINI_PATH := '/Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9;&' HOUDINI_TEMP_DIR := '/tmp' SHELL := '/bin/bash' USER := 'michaelmcneff' Workstation4:src michaelmcneff$ Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 13, 2011 Author Share Posted January 13, 2011 Sorry, I can see from your "hconfig -ap" that the HOUDINI_PATH variable is correct. Can you post the output of HOT build process, ie > hython setup.py build Also can you post the output of > ls -lR /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9 -Drew Hey Drew, Here's the results of running hython setup.py build (Do I need to change directories before running that command?) Workstation4:Resources michaelmcneff$ hython setup.py build hython: can't open file 'setup.py': [Errno 2] No such file or directory Here's the results of running ls -lR /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9 Workstation4:Resources michaelmcneff$ ls -lR /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9 total 0 drwxr-xr-x 3 michaelmcneff staff 102 Jan 12 16:20 config drwxr-xr-x 5 michaelmcneff staff 170 Jan 12 16:20 dso drwxr-xr-x 8 michaelmcneff staff 272 Jan 12 16:20 examples drwxr-xr-x 3 michaelmcneff staff 102 Jan 12 16:20 otls drwxr-xr-x 3 michaelmcneff staff 102 Jan 12 16:20 vex /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/config: total 0 drwxr-xr-x 4 michaelmcneff staff 136 Jan 12 16:20 Icons /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/config/Icons: total 16 -rw-r--r-- 1 michaelmcneff staff 2100 Dec 28 12:50 SOP_Cleave.icon -rw-r--r-- 1 michaelmcneff staff 2791 Dec 28 12:50 SOP_Ocean.png /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/dso: total 6640 -rwxr-xr-x 1 michaelmcneff staff 84968 Dec 28 12:50 SOP_Cleave.dylib -rwxr-xr-x 1 michaelmcneff staff 1693360 Dec 28 12:50 SOP_Ocean.dylib -rwxr-xr-x 1 michaelmcneff staff 1616920 Dec 28 12:50 VEX_Ocean.dylib /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/examples: total 3256 -rw-r--r-- 1 michaelmcneff staff 289708 Aug 12 02:45 sop_flotsam.hip -rw-r--r-- 1 michaelmcneff staff 277350 Aug 12 02:45 sop_mineigval.hip -rw-r--r-- 1 michaelmcneff staff 269082 Aug 12 02:45 sop_simple.hip -rw-r--r-- 1 michaelmcneff staff 273036 Aug 12 02:45 vop_displace.hip -rw-r--r-- 1 michaelmcneff staff 210697 Aug 12 02:45 vopsop_foamparts.hip -rw-r--r-- 1 michaelmcneff staff 335939 Aug 12 02:45 vopsop_two_sources.hip /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/otls: total 32 -rw-r--r-- 1 michaelmcneff staff 12466 Dec 28 12:50 HOT.otl /Users/michaelmcneff/Library/custom_plugins/hotbin_osx_H11.0.581_1.0rc9/vex: total 8 -rw-r--r-- 1 michaelmcneff staff 16 Dec 28 12:50 VEXdso Workstation4:Resources michaelmcneff$ Thanks! Quote Link to comment Share on other sites More sharing options...
eloop Posted January 13, 2011 Share Posted January 13, 2011 The "hython setup.py build" is the command you ran to build the binary dist, it has to be run in the src directory of the hot source. But it looks like everything is in place, the last thing I'm wondering is if you are running houdini from the command line after you have verified you have the HOUDINI_PATH set correctly. Mac Apps run from the Finder/Dock won't see environment variables set in a .profile/.bash_profile file or typed into a Terminal window. For things to work from a GUI launched Houdini you may be able to setup your HOUDINI_PATH in a "houdini.env" file, check the houdini docs on "houdini.env". If you are really interested slog through this http://stackoverflow.com/questions/135688/setting-environment-variables-in-os-x Being an old unix user I always start houdini from the command line. -Drew Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 13, 2011 Author Share Posted January 13, 2011 The "hython setup.py build" is the command you ran to build the binary dist, it has to be run in the src directory of the hot source. But it looks like everything is in place, the last thing I'm wondering is if you are running houdini from the command line after you have verified you have the HOUDINI_PATH set correctly. Mac Apps run from the Finder/Dock won't see environment variables set in a .profile/.bash_profile file or typed into a Terminal window. For things to work from a GUI launched Houdini you may be able to setup your HOUDINI_PATH in a "houdini.env" file, check the houdini docs on "houdini.env". If you are really interested slog through this http://stackoverflow.com/questions/135688/setting-environment-variables-in-os-x Being an old unix user I always start houdini from the command line. -Drew Hey Drew, Can you tell me how to launch Houdini from the command line? I'll give that a go and see if it works. Thanks for your help! Best regards, Michael Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 13, 2011 Author Share Posted January 13, 2011 Hey Drew, Can you tell me how to launch Houdini from the command line? I'll give that a go and see if it works. Thanks for your help! Best regards, Michael I figured it out how to launch Houdini from the command line. Unfortunately, after launching it from the command line HOT was still not working. Thanks for your help today. I don't want to monopolize your time though. I'll see what I can do to get HOT running on my own. Thanks again, Michael Quote Link to comment Share on other sites More sharing options...
