eloop Posted January 13, 2011 Share Posted January 13, 2011 Lets see if we can't get to the bottom of this. In a Mac Terminal window - $ cd /Library/Frameworks/Houdini.framework/Versions/11.0.581/Resources/ $ source houdini_setup The Houdini 11.0.581 environment has been initialized. #.....................now make sure you have HOUDINI_PATH setup ok, finally run houdini ............. $ houdini I figured it out how to launch Houdini from the command line. Unfortunately, after launching it from the command line HOT was still not working. Thanks for your help today. I don't want to monopolize your time though. I'll see what I can do to get HOT running on my own. Thanks again, Michael Quote Link to comment Share on other sites More sharing options...
photoreel Posted January 13, 2011 Author Share Posted January 13, 2011 Success! That did the trick! Thanks so much for your help! HOT now works and I'm also able to open your example file. Thanks again! Best regards, Michael Quote Link to comment Share on other sites More sharing options...
