Ezz Posted January 14, 2011 Share Posted January 14, 2011 Hi Houdini-Folks. I have a few questions about fluids in Houdini. I am trying to port my knowledge from Maya to Houdini, and in that process I have ran into a couple a things. 1) is there an option to control the Simulation Scale Rate, like in Maya ? 2) why will the fluids not display/render when I am turning of Emit Smoke from Fire in the Combustion options in the pyrosolver-node? Any help would be much appreciated. Thanks Erik Quote Link to comment Share on other sites More sharing options...
Mikal Posted January 15, 2011 Share Posted January 15, 2011 Hi Erik.. 1) You can scale simulation time... at the top level of the dopnet there's a variable called 'Scale Time'. Unfortunately, as far as I know you can't key this value as you can in Maya. 2) I've noticed this issue on the Flames preset of the pyro-nodes. I think as there's only fuel emission in this setup... turning off the Emit Smoke from Fire results in an empty density field, and returns something odd in the shaders. If you delete (or don't import) the density field from the dopnet then the shaders will work. M Quote Link to comment Share on other sites More sharing options...
Ezz Posted January 16, 2011 Author Share Posted January 16, 2011 Hi Michael. Thank you very much for your answer :-) Cheers Erik Quote Link to comment Share on other sites More sharing options...
