Easy bounding box question
Hi, probably a very simple answer but I just cant seem to find it. How do you check if a point of one object is within the bounds of another object?
Thanks
You can either use the "bound" SOP for getting any Objects or Points Bounding,
or the other option you have is using the Delete SOP and choose by "bounding Volume".
you can also use VEX nodes "Bounding Box" and "Point in Bounding Box"
Hope that helps,
Cheers
Ronen.
