Question about Houdini choppywater displacement shader
CSN0309
Hi,guys
Just a quick question about Houdini choppywater displacement shader...
Is that possible to modify this node on node level? Because i want to make this choppywater shader mix with other noise shader or texture.
Currently, this node only offers some limited parameters to play with(by my understand).. so how can i get this node into VEX network so that i can mix it with other displacement shaders or textures?
Edited by CSN0309
well technically you could recreate the shader in vops since you can view the VEX code for it. the functions called "aaWorley" which i assume means anti-aliased worley noise so it cant be much of a stretch to make in vops
as for just a direct plug'n'play i dont know though
Edited by ikarus
ya, Macha, i have already look at your post, i think i have to build it from scratch, at least i can see the code...
And i will ask this question on this friday when SideEffect guys come to my school....wow..hope i can find a quick way to take advantae this old shader....
