contrail FX Tool broken?
Netvudu
hi there,
can you guys confirm the contrail tool from the download shelf is broken? I mean, you can make it work getting into it, and changing the sprite shader it uses for some new one, or one of the two sprite shaders from the gallery, but the default shader that comes within the tool doesn´t work anymore.
The case of the Heavy smoke tool is a different one. The tool works as usual, but I tended to grab the shader for my own scenes as I found it a nice metaball shading solution. But when I do this (which tended to work before H11) it doesn´t seem to work anymore...can you confirm as well?
I know we got the new Mantra Surface shader, but I don´t understand why SESI took out several of the old ones. Some of them were useful for quick things.
