Load bgeo file with Python?
erik
Is it possible to load a .bgeo file using Python? I am trying to do some testing and want to be able to run the python scripts without having to start Houdini, and therefore I would like to be able to just load a simple test file from disk and access its geometry which will then be used.
Google gives me a blank and I cannot find anything in the docs.
  • 1 month later...
This would need Houdini to run and one License would be consumed.
The only possibility at the moment would be to use http://sourceforge.net/projects/houdinigpdlibra/ via swig ( semi automatic python wrapper generator for c++ libs )
Another drawback is that the lib doesnt support all aspects of bgeo ( volumes are not supported among other things )
