Creeping bones
loudsubs
I've crept a line on a deformed grid. I then created some bones from the crept line. Initially the bones fit with the curve, but as I translate the creep across the UV space, the bones dont stay oriented. I want the bones to stay with the curve and orient themselves according to the points of the line.
Seems like the follow curve kinematics would be the answer, but I'm not getting the result. I also tried using point expressions in the goal object of each bone and the root to reference the line, but that wasn't working either. Any ideas? Thanks
creepBones_v2.hipnc
you need to do a few things to get this to work
see attached file
you point SOP to add normals should be set to something other than $NX, $NY, $NZ - I set it to 0, 0, 1
a good tip here is whenever you mess with point normals turn on display of normals...to see what's happening :)
the root of the bone chain needs to move with the 0 point of your curve
and the bone length needs to adapt to the length of the deforming curve - measure the curve / # of bones in bone length
HTH
creepBones_v3.hipnc
