Lightwave "Diffuse Sharpness" in Houdini?
barad_dur
The closest equivalent is "roughness" parameter of oren-nayer lighting model, which might or might not be enough for you. You're also free to write tweak models (or scratch new one), sharper for example, if that's what you're after.
Stretching Lambert model with fit() or pow() is a first thing I would think of, but there must be some models designed for that purpose, like Minnaert model made specially for astronomical observations. See rough example.
cheers,
skk.
sharp_lambert.hipnc.zipFetching info...
