Creating SOP asset that uses Groups
hopbin9
I have an OTL asset that takes two inputs of geometry. I want to be able to define what point groups it should work on, but I can't find a interface parameter that I can add to the assets interface to select groups. The best I've be able to do is use a string field and then use that, but it doesn't have the drop down for selecting groups by name.
Is this possible or is it a complex thing to do.
Thanks,
you probably have some nodes inside asset that are able to work on specified groups
that nodes have Group parameter already
you can simply promote that parameter to your asset in Type Properties... dialog
either drag&drop Group Parameter in there
or chose it from From Nodes Tab
you'll get that menu automatically
you can make your own menu based on any data you want, but this should be enough
