Import Block
LaidlawFX
So the short version is I get it to work, but it loads the node name as a header to the label and name. I need to remove this for the system to be efficient. Has any one done this or a work around for it? I don't want to use a space as the sub-node name, and I can't use a call back script since not all parameters have one.
The longer story, is I'm trying to get an Import Block(A folder parameter in the interface that's type is set to Import Block, that loads another nodes parameters) to work in a series of nested assets. I get it to load the second nodes stuff by checking Import Settings and setting Source to op:<node name>, and currently leaving token and mask blank. Also I need to check off the Available for Import on all the other folder directories in the sub node. And then subsequently needing, and not passively using the refresh imports under the gear icon.
hip file won't load, otherwise i would have
nm... of course the next suggestion is in the gear menu uncheck Prefix Linked Parameter Name with Source Node Name, and Prefix Linked Parameter Label with Source Node Label. This would have help loading parameters from subnets a very, very, very long time ago.... like why it shouldn't be a default if all it will do anyways is just append a number to it...
