remlorestudios Posted February 17, 2011 Share Posted February 17, 2011 (edited) Hello to everyone at this forum. Novice here. My first problem encountered using Houdini. It seems the file1 node isn't writing out cache files (*.sim), nada zip nichivwa Trying to cache out a fluid sim. Have the file1 node connected to the gravity in the AutoDopNetwork.. should write out the files... :/ What might be wrong? Z:/temp/baked$SF4.sim using that path just to test... nor is the a geometry cache working either... so it seems I can't write out to cache files... Edited February 17, 2011 by remlorestudios Quote Link to comment Share on other sites More sharing options...
remlorestudios Posted February 18, 2011 Author Share Posted February 18, 2011 Hello to everyone at this forum. Novice here. My first problem encountered using Houdini. It seems the file1 node isn't writing out cache files (*.sim), nada zip nichivwa Trying to cache out a fluid sim. Have the file1 node connected to the gravity in the AutoDopNetwork.. should write out the files... :/ What might be wrong? Z:/temp/baked$SF4.sim using that path just to test... nor is the a geometry cache working either... so it seems I can't write out to cache files... Quote Link to comment Share on other sites More sharing options...
remlorestudios Posted February 18, 2011 Author Share Posted February 18, 2011 Well it's working now. Seemed I had to select the Display (blue) then it cached out the files... hmmm and the geo.. samething. Quote Link to comment Share on other sites More sharing options...
