Closest point on the primitive
I want to find the closest point on the primitive from one critical point using HDK.
Actually, it is easy to solve this problem( using the class : MMeshIntersector MPointOnMesh, function : getClosestPoint ) in Maya API.
Is there any similar class or function(GEO type)?
Edited by zzangxx
zzangxx,
there are some routines available in GU/GU_RayIntersect.h (w/ GU_FIND_CLOSEST)-- it looks like it takes a GU_Detail so I guess it would have to populated one primitive at a time. Perhaps there's a more incremental function version out there?
-s-
Thank you for your response.
However, I already saw that header. It include some functions that is sendRay,minimumPoint, proximityPoint and so on.
That function's return value is int type. I want to know the closest point on the primitive (input : primitive , one point // output : closest point).
How can I use that?
Edited by zzangxx
How can I use that?
use GU_RayIntersect::minimumPoint()
this stores the closest primitive with uv values of the clostest point in GU_MinInfo::Prim.
then you have to use GEO_Primitive::evaluateInteriorPoint() which returns the actual position of the closest point as UT_Vector4.
hth.
petz
Edited by petz
  • 3 weeks later...
