djwarder Posted February 22, 2011 Share Posted February 22, 2011 Hey! I'm doing a proof of concept test using FLIP fluids & was wondering if it's possible to export (or cache out) the velocity & density fields from the FLIP solver? Ideas anyone? Cheers Dan Quote Link to comment Share on other sites More sharing options...
mawi Posted February 22, 2011 Share Posted February 22, 2011 Hey! I'm doing a proof of concept test using FLIP fluids & was wondering if it's possible to export (or cache out) the velocity & density fields from the FLIP solver? Ideas anyone? Cheers Dan One way is to bring them to SOPs with DOP import fields node, then write it from there via file node. Or you could use a file data DOP and cache it in DOPS as simdata. Never use it myself, but by reading the help card you might find out how it works. Quote Link to comment Share on other sites More sharing options...
Macha Posted February 23, 2011 Share Posted February 23, 2011 (edited) Dan, try this: fields.hip Edited February 23, 2011 by Macha Quote Link to comment Share on other sites More sharing options...
djwarder Posted February 23, 2011 Author Share Posted February 23, 2011 Cheers for the help guys, didn't think it would be that easy but does exactly what I wanted! Just need to work out how to get density too, but wonder if this is stored on a per-particle level, will have a dig around ... Quote Link to comment Share on other sites More sharing options...
Macha Posted February 23, 2011 Share Posted February 23, 2011 (edited) Hey Dan, try this. You can import all kinds of fields but some may not visualize easily. Pressure, for example, is not in a neat normalized 0..1 range, so you have to use the volume visualize sop to see it. fields.hipnc Edited February 23, 2011 by Macha Quote Link to comment Share on other sites More sharing options...
djwarder Posted February 24, 2011 Author Share Posted February 24, 2011 Thanks again Macha, will have a play around with that now! Quote Link to comment Share on other sites More sharing options...
