Deform Geometry with particle(TP blurp)
xarchx
I'd say, cookie your geometry, use the intersection to emit, and then use an attract pop. However, I always find the attract pop very hard to control. For the box particles, grow with a ramp. Your main problem here is control, I think.
I had a quick go at it but couldn't get a clean enough result to post. Maybe somebody knows a better solution to this.
Edit: The problem with the attract-pop and cookie is changing point counts (my pet problem with Houdini). The attractor doesn't work properly in that case.
Edited by Macha
Go to this tutorial series
http://www.sidefx.com/index.php?option=com_content&task=view&id=1500&Itemid=254
Somewhere in there he explains how he creates the effect that is in the image used to present the tutes. It is a good start for an effect like this
Francois Simerey, who is on this forum sometimes, used that technique to create this
