LaidlawFX Posted March 10, 2011 Share Posted March 10, 2011 Has anyone ever created a menu like the blend node "blend mask" that has 9 options? I seems like it's an original thing in Houdini that's closest sibling is the rgba mask parameter. I can use an integer and drop down menu to make it work, but it will require close to 81 options to get what that nine button display can do, since it promotes as an integer. I suppose I could write a code based on 9 toggle switches, but I wouldn't know where to start, plus the original buttons look prettier, and I would still need to make the menu of 81 options I think. My primary reason is that I can't promote that parameter up to a subnet. Quote Link to comment Share on other sites More sharing options...
graham Posted March 10, 2011 Share Posted March 10, 2011 Unfortunately it's one of those things that isn't available outside of that node and possible the HDK. Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted March 11, 2011 Author Share Posted March 11, 2011 Unfortunately it's one of those things that isn't available outside of that node and possible the HDK. doht!!!! Quote Link to comment Share on other sites More sharing options...
