Curl Noise
Strife
In a dopnet? What exactly are you trying to achieve? There is a curl vex, so that would be available in a gas field vop, vop force, and other nodes that can use vex, or a popnet that sits in a dopnet.
If you are more specific we can help you better.
Hm, hard to tell from that, but some time ago Aracid gave some good advice regarding varying fluid emission. Here is the thread:
I think just adding noise or curl after a sim is likely to look artificial. You need to add it before or during sim, and emission is a good place to start. At the moment you just have a plane emitting pretty much uniform amounts of particles.
Edited by Macha
