extrude link to primitive position
jodokub
hi everybody,
i am just at the beginner level and i am searching for some expression or maybe there is also a other way for solving this problem.
i would like to modell a shaped grid and and have for each primitive a different inset value of extrudtion linked to the position.
i am sure there must be a way to link my inset value of my extrude node to the y position of my primitive.
for better understanding i attached a jpg of my viewport.
so there should be more extruding for the "higher" primitives.:)
it would be totaly nice if someone have time for this question.
thanx a lot
jodokub
Hi jodokub,
One way to try: Perhaps use the $BBY variable to drive the extrusion distance?
1. Create an attribute, call it something like exheight, and put $BBY into the value.
2. Place it just after you deform your mesh to give it height.
3. Use an attribute promote sop to promote exheight from point to primitive.
4. In your extrude SOP, use the $EXHEIGHT for the extrusion depth in the Translate Z paramater.
I don't have Houdini open at the moment to check, but I think that should work.
Hope it helps,
Matt.
