writing help for shader
Omy
hi i want to display a caption when the user puts his cursor over the material parameters.
I have seen the houdini help
basic syntax for help is
#pragma help "abcdefghi"
however after i recompiled the houdini code and try to test.I dont get the text in the dialog
help needed
Many thanks
#pragma help is for writing help for the overall operator. To add a "tooltip"-style popup help for a single parameter, use #pragma parmhelp
#pragma parmhelp parameter_name "text"
Sets the tooltip that appears when the user hovers over parameter_name.
#pragma parmhelp amp "Increase this value to add more noise."
displacement bumpy(float amp=0) {
