giumun Posted March 22, 2011 Share Posted March 22, 2011 I have some problem whit the network rendering... when it render on multiple machine some path doesn't work properly. Really need some help. i don’t understand what is wrong. On my project i have: 1: Environment light with an Environment map and the path is: \\computername\drive\folder\texturename. jpg 2: obj tube whit mantrasurface to apply on the surface mantra i have basecolor map with the examination path .... \ \Computername\drive\folder\texturename.jpg The light find the texture But The material no, I'm using the same path whit the same texture file. I set up the Hserver service with the computer administrator log and pass. Some one can help me? Quote Link to comment Share on other sites More sharing options...
giumun Posted March 22, 2011 Author Share Posted March 22, 2011 solved the path was wrong i wrote the \ instead / slash. but i still don’t know why the wrong path work whit the light map. Quote Link to comment Share on other sites More sharing options...
kubabuk Posted March 23, 2011 Share Posted March 23, 2011 Please provide more info: your OS, H build, are you rendering remotely (mantra -h) etc. You'll find some useful hints here: http://odforce.net/wiki/index.php/MantraRemoteRendering I would check if the firewall is disabled on each machine in the first place. If that won't help try to use UNC paths instead of computer names in the output paths. Quote Link to comment Share on other sites More sharing options...
