face normal help
Thank you LaidlawFX .
The points have the right normal as you said.
but about the animation I still have problems.
I want to put the every primitive pivot to the root ,make them open like flower open. Are there some expressions like $BBX , $CEX .. to calculate the root.
and It seems dosenot work to use the surface node primitive as template to rot every piece open.
please give me some ideas,thanks!
there is centroid() to grab from other nodes, and you can use $CEX, $CEY, $CEZ .... if you use a for each loop sop and set it to primitive you can find the centroid of each face and rotate based on that. My brain isn't clicking on what you exactly want.
So here are the standard variables you could look up too
http://www.sidefx.com/docs/houdini11.0/nodes/sop/standardvariables
Maybe center of mass is what you are looking for? comx, comy, comz
If you get the example LayerOGL.hip from here and just replace the ogl stuff with your transforms animation that could help, too. since it is the for each loop as mentioned above, playing around with the transform axis sop
Thanks for you time LaidlawFX!
Here is what I want to do ,I want each primitive rotation along its own direction,and finally form the object.
You can see all the primitives rot the same direction,that is the problem!
In this project ,I use the point which the each primitive center as primitive node's template ,to transform the rot scale....
In some case,object like cube ,I can use the group node to separate four group according normal direction. But a random object,rotation is the problem!
http://www.vimeo.com/21596322
Wang that building animation is a single grid(maybe a couple) copied to all those points. That set up is different than the set up of the sphere and marc's teapot, by me and marc's first estimate. The closest thing you could do to repeat that on the sphere is take a box/tube and taper(twist), or distort by grabbing groups and tranforming them into smaller sizes, into a sphere in order to make it appear like it is directly a sphere object that did the animation, too. That way you can guarantee to get a mid point at the bottom of the grid to unfold. Then you can copy sop it to kingdom come.
One node you can use is the point sop and plug your undistorted object on the left and on the right input plug in your distorted and plug into position tx2, ty2, and tz2. You can do this simple in vops sop too if you are feeling ambitious.
Good luck on your hmwk. I miss those assignments. lol.
