Another Python Question
few_a_fx
Adding some new features to my fx tool. I'm using a trail and cache node now, and I want to be able to clear the cache SOP without going to the cache node and clicking clear. I've create a button for the "clear cache" parameter on my wxPython GUI, now I'm stuck on this. If anyone knows how to clear the cache sop through python that would be very helpful.
you could do this:
node = hou.node( '/obj/geo1/cache1' ) #point at your cache node
node.parm('clear').pressButton() #and call its onPressedButton function
if you put these lines in a function, you can do a callback to this function from the button you have created in your UI
Cheers,
Emanuele
you could do this:
Cheers,
Emanuele
For the onPressButton function, do I have to write a callback script for this to work?
No. The function call will execute any internally defined events, as well as callbacks you have added.
Then do I have to put anything in the .pressButton() parentheses? I just put those to strings in my code and nothing is happening when I click the button.
Nope. It should just execute the button and be happy. I just tested it out on a Cache SOP, as well as the Reset button on the Edit SOP and both worked as expected.
I must be putting it in wrong then, because its only clear the cache when I press the button on the cache SOP and not on my python GUI. Here's the code I have.
def clearCache(self, event):
        try:
            node = hou.node('/obj/Rain_System/TRAILING') #point at your cache node
            node.parm("clear").pressButton() #and call its onPressedButton function
        except:
            exc_log
Here's the wxPython scripts for the GUI:
def _add_trails(self):
        trails_sizer= wx.BoxSizer(wx.HORIZONTAL)
        self.flex_grid_sizer.Add(trails_sizer, flag= wx.ALIGN_CENTER_VERTICAL)
        self.trail_on= wx.CheckBox(self, label= "On/Off")
        trails_sizer.Add(self.trail_on, 0, flag= wx.ALIGN_CENTER_VERTICAL)
        self.trail_on.Bind(wx.EVT_CHECKBOX, self.TrailOn)
        self.clear_button= wx.Button(self, label= "Clear Cache")
        trails_sizer.Add(self.clear_button, 0, border= 10,
            flag= wx.LEFT|wx.ALIGN_CENTER_VERTICAL)
        self.clear_button.Bind(wx.EVT_BUTTON, self.clearCache)
