ranzen Posted April 1, 2011 Share Posted April 1, 2011 Hello, I have following animation of two RBDs and three wires and can`t figure out how to change the material of the dynamic objects. I want it to be basic clay - as the background Thanks in advance! FLOWERCONSTRAINT.hipnc Quote Link to comment Share on other sites More sharing options...
ben Posted April 1, 2011 Share Posted April 1, 2011 On your node sphere2 uncheck "Matte Shading" (render/shading/matteshading). I assume you checked it by mistake. Also you should uncheck the display flag on the AutoDopNetwork. Quote Link to comment Share on other sites More sharing options...
ranzen Posted April 1, 2011 Author Share Posted April 1, 2011 On your node sphere2 uncheck "Matte Shading" (render/shading/matteshading). I assume you checked it by mistake. Also you should uncheck the display flag on the AutoDopNetwork. Hi Benoit, thanks a lot! Your suggestion solved the problem. Quote Link to comment Share on other sites More sharing options...
