Need help with parent constraint
wildr3d
Hey everyone,
I have an object that needs a swinging object attached to it as it moves. The object is being moved
with an Mdd file from Maya and I got a rivet to attach to a point on the Mdd'd object and am able to
parent the object that needs to swing to the rivet. I set the RBD pin constraint up ,but when I try to
parent constraint that to the rivet it doesn't move with it. Can I make this work or are there any other
ways to do this?
Thanks,
Ken
