Eitht Posted April 9, 2011 Share Posted April 9, 2011 G'morning, encountered these render artifacts while using dent_fractal. At first i thought the problem lies in my rock geo, not until i unplugged the displacement shader and all of them were gone. Low or high values for the displacement didn't make them go away. I turned to Micropoly instead of PBR which miraculously gave me a much better result with tiny black spots still haunting me. Really puzzled what's happening here, somebody please. =_= eitht. antiAliasedNoiseVOPSOP.hipnc Quote Link to comment Share on other sites More sharing options...
DanBode Posted April 9, 2011 Share Posted April 9, 2011 This is a classic displacement bounds issue. What's happening is that your displacement shader is pushing geometry beyond the bounds that mantra has defined. To fix this drop a Properties SHOP, connect it to the suboutput in your material, and add the displacement bound rendering property. A value of .1 seems to work in this case. Quote Link to comment Share on other sites More sharing options...
Eitht Posted April 10, 2011 Author Share Posted April 10, 2011 This is a classic displacement bounds issue. What's happening is that your displacement shader is pushing geometry beyond the bounds that mantra has defined. To fix this drop a Properties SHOP, connect it to the suboutput in your material, and add the displacement bound rendering property. A value of .1 seems to work in this case. danBode, second time you've helped me out. Problem solved, have a good day! Quote Link to comment Share on other sites More sharing options...
