Vex question
Macha
I'm not sure if there's a function which could do that straight away..but I guess if you loop through the points with a for loop and sort of assign ptnum to a variable you will get the point numbers. Now i'm not sure whether they would be sequential. The for loop could get the data from the geometry but I'm not sure of the order of the points..will give it a try and let you know.
erm..just to clear things up..you need this array of points to be ordered based off what??
Proximity and connectivity. Then sort, create an ordered, increasing attribute and sort sop. Something like that.
