MoSobhy Posted September 15, 2003 Share Posted September 15, 2003 hi guys, How knows how to implement readArchive in Mantra? Thanks Mo Quote Link to comment Share on other sites More sharing options...
Jason Posted September 15, 2003 Share Posted September 15, 2003 Absolutely: In the objects parameters, go to the Render tab: Change "Geometry: Geometry as is" to "Render from file" and specifify the BGEO file underneath to render. This is the ReadArchive equivalent. -or Change to "Bounded file" for the DelayedReadArchive equivalent, which will only read the file if the bounding box is struck. You have a couple of options to specify the bounding box, both very self-explanatory in the menu options there. Try it out and post again if you have troubles! Ciao, J Quote Link to comment Share on other sites More sharing options...
