Volume VOP inline code
hellomrjack
Hi, Im currently trying to make a Volume VOP node that will be able to strip out all densities except in a narrow range. I was thinking of using an inline code node containing something like this:
$outDensity=0.0;
if ($density>1.1)
   if ($density<1.2)
      $outDensity=$density;
The name for my output is outDensity.
Am I going about this the write way? Even when I just use:
$outDensity=1.0;
It wont just set everything to 1.0.
Thanks
Jack
I can't help you with your code at the moment (no Houdini around), but I would suggest to take a look on VolumeRampSOP or using clamp() function or recreating volumeramp with vex's ramp parameter. Conditional statements (if/then) misbehave, since they output unfiltered data.
Here is something silly I played with.
I like the ramp but the problem I often have with it is it's range 0..1 and the lack of control you have over the curves.
So here is a version of the ramp that uses bezier curves. Woohoo!
Just for fun, don't expect wonders.
Edit: The volumevop in that network serves no purpose. I forgot to delete it.
sillyvol.hipncFetching info...
Edited by Macha
