beeemtee Posted May 4, 2011 Share Posted May 4, 2011 (edited) Hi Everyone, can someone explain me how the Surface Model node exports separate indirect contribution planes, like "indirect_diffuse" for example. I'm unable to find the parameter node which exports the plane. Not even "opfind indirect_diffuse" inidicates that there is one.. Is the export code implemented at the API level? If so in which node is it? Thanks in advance Mate Edited May 4, 2011 by beeemtee Quote Link to comment Share on other sites More sharing options...
anim Posted May 4, 2011 Share Posted May 4, 2011 it's quite funny they are just Parameter VOPs but they are not named accordingly, so you cannot find them by name they are called : parameter1 for Ce parameter2 for direct_reflex parameter3 for direct_specular parameter4 for direct_diffuse . . . parameter15 for indirect_reflect and so on, some are in different subnets, but usually not named accordingly as a VOP node Quote Link to comment Share on other sites More sharing options...
beeemtee Posted May 4, 2011 Author Share Posted May 4, 2011 Thanks Tomas, while I was aware of the 'direct' parameter nodes, whith your help I found a bunch of other parameter nodes. Since the inners of the Surface Model node shows the signs of heavy pastafarian influences, I decided to write a little script that does the search instead of me. Here is the output: /obj/SHOP/Test/surfacemodel1/parameter4: direct_diffuse /obj/SHOP/Test/surfacemodel1/parameter2: direct_reflect /obj/SHOP/Test/surfacemodel1/parameter3: direct_specular /obj/SHOP/Test/surfacemodel1/parameter12: direct_volume /obj/SHOP/Test/surfacemodel1/parameter5: direct_refract /obj/SHOP/Test/surfacemodel1/parameter6: direct /obj/SHOP/Test/surfacemodel1/parameter7: direct_noshadow /obj/SHOP/Test/surfacemodel1/parameter8: direct_shadow /obj/SHOP/Test/surfacemodel1/parameter13: direct_samples /obj/SHOP/Test/surfacemodel1/if2/multiglobclr: multiglobclr /obj/SHOP/Test/surfacemodel1/if2/parameter1: sss_single /obj/SHOP/Test/surfacemodel1/if2/parameter2: sss_multi /obj/SHOP/Test/surfacemodel1/parameter14: indirect_refract /obj/SHOP/Test/surfacemodel1/parameter15: indirect_reflect it's clear that "indirect_diffuse", "indirect_specular" and some other planes are not exported this way. So the question now is, where those "missing" planes got exported? Just for the sake of completeness, here is the code of the script: nn = hou.hscript("opfind -p /obj/SHOP/Test/ -t parameter")[0].split() p = [(n,hou.node(n).parm("parmname").eval()) for n in nn] for l in p: print l[0] + ": " + l[1] Thanks Mate Quote Link to comment Share on other sites More sharing options...
anim Posted May 4, 2011 Share Posted May 4, 2011 for PBR, you probably need to look at pbrexports.h and pbrpathtrace.h files I don't know if "missing" export variables are valid for non-pbr, I am not sure that for example if indirect_diffuse works with non-pbr, it contains nothing when rendered with mp or rt with env + indirect light, 1 diffuse limit as opposed to pbr which works under those conditions Quote Link to comment Share on other sites More sharing options...
beeemtee Posted May 5, 2011 Author Share Posted May 5, 2011 Oops, I have to appologize, since my problem was an IPR refreshing problem. After switching between a Mantra Surface node and my own, those "missing" planes were evaluated to zero, and I thought I don't know how to export them. Restarting the IPR process made them evaluate correctly. It turned out that the PBR engine exports them "automatically", so no parameter nodes are needed for these exports. Thanks again for your help Mate Quote Link to comment Share on other sites More sharing options...
