Bonedaddy Posted May 4, 2011 Share Posted May 4, 2011 Hey guys, I'm inheriting an OTL with a couple VOP SOPs in it, and I'm trying to expose some of their ramp controls at the OTL level. Does anyone know a way to do this? The standard copy-paste doesn't seem to work. I'm on Houdini 11, by the by. (also: first post! if I'm egregiously breaking the rules of this forum somehow, or posting in the wrong place, I apologize) Quote Link to comment Share on other sites More sharing options...
anim Posted May 4, 2011 Share Posted May 4, 2011 you can drag'n'drop your ramp parameter to Type Properties window right between other parameters in your OTL just to keep in mind: never edit HDA's parameters through Edit Parameter Interface... if you want them persistent you must be editing your Digital Asset through Type Properties... (under rightclick on HDA node) and your node with ramp must be somewhere inside this HDA everything should work then Quote Link to comment Share on other sites More sharing options...
Bonedaddy Posted May 4, 2011 Author Share Posted May 4, 2011 you can drag'n'drop your ramp parameter to Type Properties window right between other parameters in your OTL just to keep in mind: never edit HDA's parameters through Edit Parameter Interface... if you want them persistent you must be editing your Digital Asset through Type Properties... (under rightclick on HDA node) and your node with ramp must be somewhere inside this HDA everything should work then That worked a treat! Thanks so much! Quote Link to comment Share on other sites More sharing options...
