How to create environment map?
hopbin9
How do I create an environmental map in Houdini. Need to apply a gradient as the background for testing some metal shaders, but can't figure this out.
The only thing I can think of is create a sphere and texturing it.
1. you can use env light with environment map
and if don't want it to emit light just change the mode to Ray Tracing Background
if you are not using Mantra Surface, or Surface Model then it may not work and you
2. simply use big sphere or any simple object with Environment Box material from palette
