breadbox Posted May 7, 2011 Share Posted May 7, 2011 (edited) how would i set two keyframes and hten in the channel editor make the post infinity graph after the second keyframe continue along the same tangent. maya has a similar function where you can take a curve and say post infinity continue and say you had aninated 2 keys at 1 and 20. the animation would continue on the curve for infinity. I could go to motion effects and add a slope but this seems a bit more complicated wonder if there is a more simple method. Edited May 7, 2011 by breadbox Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted May 7, 2011 Share Posted May 7, 2011 Documentation Quote Link to comment Share on other sites More sharing options...
katisss Posted May 10, 2011 Share Posted May 10, 2011 (edited) hi, is there also something like "linear" infinity useful for motionblur? EDIT: http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=5754&view=next&sid=84b14f22b4cf86a05e76dbf1501f24a8 Edited May 10, 2011 by katisss Quote Link to comment Share on other sites More sharing options...
bastian Posted August 1, 2016 Share Posted August 1, 2016 (edited) FOUND IT! for anyone coming in from google. In Animation Editor > right click the channel and choose 'Channel Properties' or just press Alt+E. A window will pop up where you can change the option for how houdini will interpret the channel beyond the keyframes from "extended" to "cycle" or "cycle with offset" Edited August 1, 2016 by bastian 3 2 Quote Link to comment Share on other sites More sharing options...
mestela Posted October 27, 2016 Share Posted October 27, 2016 Heh, you read my mind bastian; 3 of us were stuck for 20 minutes today trying to find that menu, then i remembered someone had posted it on odforce. WHY IS IT SO HIDDEN SIDEFX, GRRRR 1 1 Quote Link to comment Share on other sites More sharing options...
