CHOP Deformation lag : Need help !
Hello,
I am trying to make the lag within CHOP and I have a problem ( again ).
If you look at the picture attached, You can see a channel coming from a geometry ( called voldiff). What I would like is my lag only react when the value of voldiff is under or equal to zero.
How It could be possbile in CHOP ?
Thanks for your help.
Vincent
Thanks for your example Anim but in if your hip you modify the part of a channel and its not exactly what I am looking for.
I would like a channel ( chan1) to be modified ( by a lag ) regarding the value of another channel (chan2). If chan2 <= 0 then chan1-Lag.
I just see expression node accept multiple entries. i ill try to watch the doc about that ...
Thanks again
Vincent
then this might help
1. test if chan2<0 this will give you weight channel 0 for positive 1 for negative parts
2. blur this channel a little with Filter CHOP to avoid sharp changes
3. use Blend CHOP to blend between unlagged and lagged geometry according to weight channel
here is an example
chops_lag_by_weight.hip
