Interface options
when editing parameter interface if you make a float attr it seems by default to come with a slider. is there a way to make a float box without the slider? and make it wide as the parameter pane? I'm looking for an easier way to add long expressions in float boxes.
opp ok i guess when you place the expression in the box the slider goes away and it makes itself as long as the parameter pane.
Edited by breadbox
if you click on your param name, it turns to the box that you want. + use ( alt + E) to open a bigger box if your expression is too big.
