venkat Posted June 7, 2011 Share Posted June 7, 2011 Hai, I am using a sequence of images in cop network and applied that image to pop. For single image it is working but if I apply for a sequence of images it is not updating. Can anyone help me.... cop_pop.hipnc Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted June 7, 2011 Share Posted June 7, 2011 May I ask why you're using COP? you can just use VOP SOP to do that!! Quote Link to comment Share on other sites More sharing options...
venkat Posted June 7, 2011 Author Share Posted June 7, 2011 May I ask why you're using COP? you can just use VOP SOP to do that!! Could you give me an example I am not that good in using Vop sop. I just want to use animation images for pop's Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted June 7, 2011 Share Posted June 7, 2011 (edited) ok, I've made some changes, is this what you're trying to do?. I think your file also might work if you set your pop network setting correctly(take a look at the popnet1 in my file, specially in Birth tab!), I didn't try it though, cuz I think the way that I did it is simpler! cop_pop_v02.hipnc Edited June 7, 2011 by ehsan parizi Quote Link to comment Share on other sites More sharing options...
venkat Posted June 9, 2011 Author Share Posted June 9, 2011 ok, I've made some changes, is this what you're trying to do?. I think your file also might work if you set your pop network setting correctly(take a look at the popnet1 in my file, specially in Birth tab!), I didn't try it though, cuz I think the way that I did it is simpler! Thank u Ehsan it's working... Quote Link to comment Share on other sites More sharing options...
