Particle Fluid grains
DeehrBYU
I have been messing around inside the particle fluid object for awhile now, trying to figure out how the grains are supposed to work. It seems like form reading documentation that they allow some SOP geometry to be instanced to each particle in the particle fluid, but nothing seems to be working. Has anyone had any luck with this? Thanks.
  • 1 year later...
I'm trying to use grains but it seems that there is something broken because grain geometry doesn't get copied over the points correctly. Also the particle fluid solver throws an error, missing "restdensity" attribute.
Anyone knows how to make this work?
