Adam Ferestad Posted June 11, 2011 Share Posted June 11, 2011 Trying to make my network for the light string apply to an input curve, but I am having a little bit of trouble figuring out how to get it to process through each section of my curve. I read in another thread that there is no edge attribute in Houdini, which makes it a little iffy. I also need to figure out how, once I get the edge set in the ForEach node, how to detect the individual end points for that line. Quote Link to comment Share on other sites More sharing options...
anim Posted June 11, 2011 Share Posted June 11, 2011 what is your input (linear poly curve?) what do you expect to get in each loop (just the segment?) here is a simple example of such thing there are many other methods you can use even for branched curves or poly meshes but it depends on what you want as for end points of the segment you can add custom attribute before foreach storing $PT then each point (of 2) inside foreach will contain correct number inside that attribute instead of foreach you can use VOPs and Neighbour VOP to get each segment and do something on the end points, again it depends on what you want lin_curve_for_each_segment.hip Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 12, 2011 Author Share Posted June 12, 2011 (edited) Thanks anim, that gave me exactly what I needed to be able to do it (I will definitely be giving you credit in the intro of my tutorial I am going to write. If you have a website and would like me to link your name to it, let me know.). Now if only I understood what all of it does. I understand the start value on the delete, but the end value... I'm not sure of. I haven't learned about the stamp() function yet, so I have no idea what it is actually doing. The other problem I am having with the forEach is how to get a group out or how to target my spheres to light them with the geoLight, but not target my lines. I have included my current attempt. I still get some of the quirky lighting problem where parts of the geometry don't render properly as lights with whole sections of single spheres being dark. It is a most frustrating problem. In the file I attached you can see the problem if you change the geoLight target to the forEach rather than the copy node inside of it. light_string1.hipnc Edited June 12, 2011 by Adam Ferestad Quote Link to comment Share on other sites More sharing options...
anim Posted June 12, 2011 Share Posted June 12, 2011 forEach in this mode will iterate npoints-1 times starting from 1 ending npoints-1 so for curve with 3 points (0,1,2) it is executing 2 times and since it is set to start at 1 and end on npoints-1 it will have following values on each iteration 1st iteration : value 1 2nd iteration : value 2 this value is stored in FORVALUE variable (you can change it's name) or in FORIDXVALUE (for other modes like Each Group) stamp("..","FORVALUE",1) will get the value of FORVALUE variable at the current iteration it's like copy stamping so at 1st iteration you will keep 0-1 segment in Delete SOP, at 2nd iteration segment 1-2 and so on you cannot reference something in ForEach the way you do because it doesn't exist in memory when ForEach is finished, only final computed geometry exists you need to group your spheres then recall that group after for each see the example (i have also changed render settings and attenuation on your lights so change it back if you want, I was just playing) on the other hand for what you are doing you can completely avoid ForEach and instead of copied spheres you can use instanced area lights if you just want simple shape like sphere see the second example file light_string_fix.hipnc light_string_instances.hipnc Quote Link to comment Share on other sites More sharing options...
Adam Ferestad Posted June 12, 2011 Author Share Posted June 12, 2011 Thaks for the explanation, though I don't understand what stamping does on copy sops either. I looked at your fix file for the geoLight method and i really like the way that you handled it with the blasts. I had came to the realization that I actually didn't need the copy and Wireframe branches inside of the forEach node. Once I took those branches out and did them in my geometry sop it became a very simple problem to solve. I also figured out how to do a randomized slack value for each section so an artist could give some variance to the string since that would be more realistic. Now I have to decide how I want to handle the tutorial for it. I am considering doing a roof model and having the lights use the edges of the roof to iterate through. I am slightly worried about doing a long tutorial since my other ones tend to be pretty short. Would I be better off doing the two as separate tutorials, a long one or serialized tutorials? Quote Link to comment Share on other sites More sharing options...
