animation production pipeline
Hi everyone!
this is my first topic in this forum.
I would like to ask what is usually the different phases of a character animation production in houdini.
Is everything usually made inside houdini, or the animation and modelling are made with other softwares, and then imported into houdini?
I know that there isn't a rule, but I would like to know what is the most common choice.
two other questions:
there are some guides in internet about animation inside houdini? I mean not the character animation tutorial inside the sidefx website, but a most advanced one that teaches you how to work with the curves, create animation cycles, etc...
can you link me a guide about exporting animations from other softwares and import them into houdini?
thankyou!
As far as importing and exporting I have been using FBX and have found it does work very well.
There is a plugin floating around for exporting and importing the standard bgeo format that Houdini uses for Maya, but I have not tried it.
We also use obj because a number of the other cad packages in the office use it - so models are available.
Hope this helps a little...
ok thanks, I will try to play a bit with this FBX
