CtrlLoki Posted June 16, 2011 Share Posted June 16, 2011 Hello, I have up until now been using moving geometry to break up other RBD glued objects which works fine but have seen somewhere you can use meta balls and the magnet force in DOP's to drive fractured objects almost like a C4 charge but I cannot get this to work ? I would like to Pre-fracture some geometry, read it into DOP's and have meta ball acting as a charge. I have attached my current scene file how I though it should work with the magnet scale force animating on frame 5 but still no Joy. has anyone come across this before or have any ideas how to make this work? Thanks Magnetforce_drive_Pre-Fractured.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted June 16, 2011 Share Posted June 16, 2011 I never got that to work good either. Prefer messing with the point velocities and then use inherit point velocity. voroexplode.hipFetching info... Quote Link to comment Share on other sites More sharing options...
CtrlLoki Posted June 17, 2011 Author Share Posted June 17, 2011 Good to know its not just me then and thanks for the tip/file on point velocity I will give it a try. Quote Link to comment Share on other sites More sharing options...
old school Posted June 17, 2011 Share Posted June 17, 2011 Here's the file with magnet force working fyi. Magnetforce_drive_Pre-Fractured_jw.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
